Hole in the floor
5.1K views 18 replies 16 participants last post by  toolshedj
#1 ·
So took the new '08 out this weekend. My brother ended up putting a big rock (4") through the passenger floor board.
What's the best way to repair and the guard against future carnage?
#3 ·
I was out this last weekend and put a hole in my passenger floor board. Thanks for the repair idea will try to fix it this coming weekend.
#4 ·
I have a hole in my passenger floor also,and i never thought anything of it either.now every time ,i mean every single time, a stick always manages to find its way back through the floorboards.I bought the floor thing from eBay,no more problems.
#7 ·
mine happened where the pass feet are.
#11 ·
^ similar to what happened to mine except mine didn't come through the floor it just cracked the plastic
#12 ·
I got these at hunterworks after I poked a hole through.. These just cover the damage. They are only held in place with self tapping screws into the plastic. I added some bolts with vinyly nuts so they didn't pop up every time something hits the floor.. On my next Rhino, I will just put the floor protector skid plates on the underside before the first ride...
#15 ·
I fixed my hole by stitching it back together with pull ties.
#19 ·
Look on ebay, they have diamond plate floorboards and guards for underneath.I put both on my 05 rhino, it had a busted floorboard when I got it.You can drill out the factory rivets ( that hold the floor boards on ) and put self-tapping screws through the diamond plate floorboards to hold them tight.The underneath guards come with all the hardware and instructions.The seller I got mine from is leroy870 , I think.If you ride in the woods, your going to bust your floorboards without these guards!
